Bro after updating battery maximum percentage reduced to 97% and before upgrading it was 98% battery max capacity is there any problem??
do calculate battery health from the month of purchase bro. explained in the following episode.
it could be a refresh mostly happened after software update. so dont worry and continue with the charging practice bro. have a good day.
Thank you bro I have a doubt if is below 20 should I put low power mode does this affect my battery epoyachum epdi avum below 20 ???
You can put it on low power mode if you couldnt find any charger nearby. even at 10%, you can charge occasionally, bro. no problem in that. our objective is not to drain the battery frequently. that helps.
