Bro after updating my iPhone 13 Pro Max to iOS 16.2, not turning on 5g at all , battery life suthama koranjipochi bro , health reduced from 97 to 94 due to frequent recharge , and normal ah kedaikura battery life ippo low power mode on panna than kedaikuthu , when will this be resolved , main issue , frequent location check by system services and i really dont know what else is draining it so much . Munnadi standby la 100 charge potu vachirunthen na morning 100 maintain aagum but now it gets down to 97 in standby , screen off
Hi bro, overnight drain upto 8% is normal and it changes based on network search in our area and other apps notifications that we receive during night.
And yes, iOS 16.2 does have some battery performance problems. I am hoping for 16.2.1 update to come in two weeks to address location service usage by system services and battery drain fixes as well.
Noticing same battery performance reduce in my 14 plus too.
Yes bro but in same scenario which i had before and after update , i can note that before update my overnight standby didnt reduce even 1% but this 16.2 had such issues that it reduced upto 6 % max and relatively more battery drain during day , but then to my surprise except you , no other ytber seems to be bringing this battery issue up at all why is that ? , also is it possible to downgrade with not signed by iTunes firmware of iOS 16.1.2 via itunes windows?
As I regularly monitor battery performance and collect feedback from our users. I update it in our channel bro.
And it is possible we loosing few percentage during night for that location update too.
Network search also happens randomly and wont be stable in specific area all the time bro. That could be the reason.
Thank you bro , might as well could you say is it good to downgrade to iOS 16.1.2 and best method to do so?
16.2 fixes several high risk security problems bro. So it is not a good idea to downgrade unless current version is bothering so much. Even you can take backup of current iphone in itunes and do clean installation once and it will show some improvement till next update comes out.
