Hi , I’m using my iphone se2 for past two years,also I recently purchased airpods pro 1st gen , iphone is getting disconnected automatically while on call. I’m facing this issue only after purchasing my airpods. Is there any solution for this bro , i hope you’ll help me with this.
Hi bro, do perform “Settings - General - Reset - Reset Network Settings” once in your iPhone. then reset airpods by pressing and holding button behind the case. Then pair it fresh with your iPhone and check how the connectivity holds up after that.
let me know if that helps.
Thanks for taking such time to revert.
