Can I use Macbook m2 pro 14 inch while charging , does it effect battery life ,
for normal and heavy use how many hours battery back up will come for 14 inch m2pro, anti virus thava paduma mac os,antivirus illama mac use pannuna virus vara chance iruka
When power plug is connected, it dont use battery power bro. so not a problem. battery wont be affected. as its a fully computer, depending on apps you use it is decided. normally for browser based usage, we get 13 to 15 hours of battery backup.
antivirus for mac is not necessary bro.
mp4 vedios mp3 some other files download pana virus kaduthu virus varathuku chance irukathu illa bro mac pudusa use panran bro adan katkuran
pirated apps download la eppothume risk irukunga. avoid downloading from random websites. mac kum virus or ransomware vara chance irukunga. try to download from verified sources only bro.
