Can we use limit 80% charging setting in iPhone 15?
Can we the option “limit 80%” for iphone 15 series??
If we use magsafe charger(original) will it inprove the battery life??
Yes bro. if the 80% charge is enough for your every day usage then you may use that option. Otherwise keep optimised charging feature ON. that will automatically manage your charging speed after 80% according to your previous weeks usage. no need to manually control everything from our side.
magsafe or wired is not going to be a matter. both will not affect battery health as per my observation with people using wired most of the time and magsafe charging most of the time.
It all depends on our usage and charging practice bro. Just follow the same charging practice as suggested in our video, and it will be maintained well.
