Do i need to shutdown my macbook air every day?
Hi bro its necessary to shutdown my mac mii air everytime or else i put it on sleep mode i use often my mac need your suggestion.
and im not able to bring the folders or files to the desktop in mac guide me to do that too.
Thanks
Hello Bro,
You can put it in sleep mode and continue using it the next day. It won’t be a problem.
Where you are moving files and folders bro? you can right click on desktop and create new folder. also drag and drop files from other folders inside finder app. Do refer this mac basic video tutorial if you are new to mac computer.
