Dual Esim 14 Pro - Apple Care Plus in India
Hi Brother
I hope you’re doing good. I have my iPhone 14 pro from USA(Dual Esim). I have my apple care plus till January’25.
I dropped my phone accidentally and back glass and my screen is broken.
Can I claim accidental damages in India? Will the service centre in India take my device accept the repair/replace request with Apple Care plus?
For replacement what are the conditions?
Looking forward for your answers.
TIA :blush:
I am good bro. thank you. hoping you too. Yes you can claim applecare+ in india. a friend of mine also did claim last year and there was no issues. kindly check with nearest aptronix or iplanet service center and let them guide you further.
taking important data to icloud or google drive or local computer via iTunes will be good idea. just to prevent any data loss during the repair or replacement.
you should be able to turn off find my iPhone service using apple id and password.
No other conditions bro. they will take like 1 to 2 weeks maximum time if they have to send the unit to bengaluru for further assessment and process. Then they notify you accordingly.
