eSim and physical sim difference?
hi bro esim related my question physical and esim difference enna bro signal esim maruma tower example physical sim 3 signal bars irunda esim full 4 singnal bars kadaikuma illa ora madri tha irukuma
na esim model japan iphone 17 pro max vanga poran bro before purchasing just oru confiramtion iduku munnadi 16 pro max physical sim use pana so asking please reply esim network signal nala irukuma esim price kamya iruku
hello bro, esim kum physical sim kum network performance wise difference irukathunga. eSIM ku advantage thaan irukunga. suppose network side update ethavathu vanthaalum old sim card issue pannum. but esim is an advantage. convenience kaaga neenga one physical sim vachikalaam. but esim is best if available with your network.
Signal reception same a thaan irukumnga.
hi bro japan version esim model 17 pro max vangitan silver color thanks bro,
bro 17 pro max japan version compare vs US version, japan lighta display yellowa tharyura madri iruku , na 16 pro max usse panna adualayum apdi than irunduchu is its normal thana, settings edum mathalama , nanum internet check panna ida madri potrukanga little confusion iruku please explain
https://www.reddit.com/r/iphone/comments/1ow6nky/iphone_17_pro_screen_looks_yellowgray_compared_to/
congrats on your new iPhone bro. yellow tint normal white page safari la ethavathu website open pannitu paarunga. clear a visible aaguthungala? mostly true tone naala antha yellow tint irukalaam. but normal la use pannumbothu namma notice pannura mathiri irukaathunga.
thanks bro lighta tharyudu romba tharyala
then dont worry bro. normal la use pannunga. ithu romba issue aagathu namma usage la.
thanks bro , 16 pro max madri handla vatchu irukum podu premium miss agudu normal 16 plus madri iruku ,
bro thunder bolt 5 pro cable sealed forign peace iruku 3000rs solranga oru customer vangalama 17 pro maX Data transfer and mobile ios restore use panikaalama from macbook pro ,
yes bro. mostly case wear pannuvom. so camera and other features la difference irukum. coming from 16 pro max smaller difference thaanga bro.
trusted seller aanu paathu vangunga. clone or duplicates market la irukunga. paathu vaanganum bro. and yes charging and data transfer ku use pannalaamnga.
