Home and lock screen batter consume is vey high
Do you have any Idea about why iphone home and lock screen battery consume is very High i did all settings but still getting same for me 21 percentage
There are few reasons for home and lockscreen to consume more battery power. sometimes it will show in the battery graph but at different time intervals when you tap on battery activity graph section you will see very less consumption of power. so last 24 hours battery consumption is normal or less then not to worry.
Otherwise check the following.
  1. Are there any widgets or lock screen widgets enabled? like weather app to update regularly uses considerable amount of battery power, and that could result in home and lock screen usage. Any other widgets we use also becomes the reason based on how frequently it will be updated.
  2. Is the iOS updated to latest version? check and update if its running older version as bugs related to home and lockscreen released in recent updates that will help us to see improvements.
Do try above suggestions and let me know bro.
