Is it ok to install ios 18 public beta on a secondary iPhone (which only I use for calls telegram etc occasionally)
Hi bro, Yes you can install and experiment it with secondary device. even if apps crash or restart happens, it will be manageable. Currently rollback or downgrade is not possible without data loss. expecting upcoming updates will fix it.
