Bro yesterday I enrolled into Beta program. When I check the update, It is only showing IOS 17 beta.
Any specific reason for that? My mobile is 15 Pro Max UAE version.
do restart the iPhone once and check again bro. I got the beta update of iOS 18 after 1 day only. in your case it may be cache related issue.
I did it bro. Still it showing only older version in beta.
Moreover, while enrolling it showing ios 17 in safari as well after entering my apple id.
the device is showing only public beta. do you have beta profiles installed under settings - general - vpn & device management section bro? If yes, can you delete the profiles present there and then restart iPhone once again. then check for beta software update?
These are VPN profiles, shouldnt be an issue bro. also its not connected. so strange, some users experience this problem. Normally if we wait in that settings - general - software update page, in few seconds we see the beta updates available.
Do perform “settings - general - reset - reset all settings” once bro.
Then restart the device, connect to wifi and check software update beta page again. let me know if you are seeing the iOS 18 Developer Beta option or not.
Still it is not showing bro. Is it because of mobile version? Mine is UAE version
That shouldnt be the problem bro. some other settings could be reason. some more users reported same problem even with indian models.
