Hi sir i am using ipad pro m1 version for past 4 years .Now i am experiencing many-colour lines on display I went to iplanet they say need to replace only is the any other option .
hi bro, sorry to know about the issue. any drop or physical hit happened to the device?? iPads are not repaired and mostly replaced entire unit at apple service center. you may check with third party service center as a last option to see if that can be fixed. even duplicate display are rare depending on ipad model.
Else checking to sell this in used market and going with new iPad is another option. depends on your decision and budget.
