iPhone 13 battery health reduced
Hi bro good evening, im using iPhone 13 since 18months. Now my Battery health has reduced to 88% is that normal or abnormal? Im using in low power mode.
Is that ok to use in low power mode always? Kindly suggest
Hello sis, good morning. its totally normal for 18 months usage. continue following the same charging practice and that will help. low power mode can be used whenever you needed it sis. thing is, with low power mode you may notice some issues related to screen refresh rate or apps hanging few times.
if no issues you can continue using low power mode.
