Recently i bought the Iphone 13 in flipkart billion day offer, I am
facing heat issue on using Camera, If other apps no issues, only if i
open camera and taking some pictures feeling heat on backside, I
updated latest software version, Its any expected behavior or i need
to check with service center for this issue. Any other settings needs to change. Getting
little warm only taking photos and videos on camera.
hi bro, do check “settings - privacy and security - location services - camera” app toggle ON la iruntha off pannunga. normal la camera app use pannumbothu heat irukumnga. location access innum fastera heat agurathuku chance iruku. so intha option off pannitu check pannunga.
once settings - general - reset - reset all settings pannalaamnga. but before than above suggestion try pannitu 3 to 4 days use pannitu paarunga. issue iruntha intha step panniakalaam bro.
