Hello Brother!
I’m just charging my iPhone 14 Pro Max according to your instructions. It has been almost 10 months, and the battery level now shows 93%. Is it usual, or am I doing something incorrectly?
10 months 7% is totally normal bro. continue following the same charging practice and it will be maintained well according to your usage.
Thank you very much. I will keep following.
