My iPhone’s display does not automatically wake up when I receive notifications while the phone is locked.
When a notification arrives, I can hear the notification sound, but the screen remains completely black. If I press the Side button to wake the phone, I can then see the notification on the Lock Screen.
Previously, the screen would light up automatically when a notification arrived, along with the notification sound. The current behaviour is different.
The problem affects notifications from all apps, not just iMessage.
However, incoming phone calls wake the display normally. This suggests that the issue is specifically related to how the display responds to notifications rather than a complete failure of the display to wake up.
I noticed this issue after using Reset All Settings on my iPhone. The problem has continued despite trying several troubleshooting steps.
I have performed the following checks:
- Notification sound: The sound plays when a notification arrives, even when the screen remains black.
- Lock Screen notifications: The notifications are configured to appear on the Lock Screen.
- All apps affected: The problem occurs with notifications from different applications.
- Incoming calls: The display wakes normally for incoming phone calls.
- LED Flash for Alerts: I enabled the rear LED flash for notifications. The flash works when a notification arrives, but the display still does not wake up.
- Dynamic Island: The Dynamic Island does not show any activity when the notification arrives and the screen remains black.
- Proximity sensor: I tested the proximity sensor during a phone call, and it appears to function normally.
- Tap to Wake: I found that enabling Tap to Wake allows me to wake the screen by tapping it, but it does not resolve the automatic screen-wake issue for notifications.
- Raise to Wake: This feature is enabled, but it has not resolved the notification issue.
- Attention Aware Features: I turned this feature off, but the issue persisted.
- Reduce Motion: This setting is off, but the issue persisted.
- Force restart: I force-restarted the iPhone using the Volume Up, Volume Down, and Side button sequence. The problem persisted.
- Software update: The phone reports that iOS 27.2 is the latest available version.
- Other notification settings: I checked notification permissions, Lock Screen notification settings, notification previews, Focus settings, and Scheduled Summary. These checks did not resolve the problem.
kindly help me this issue is killing me
