iPhone 15 not charging
Bro iPhone 15 na use panitu irukan .ipo charge podalam pathan bro 16 dha irundhuchu. Charge plug pana odaney charge agala bro . Vera c pin potalum charge agala bro . Then phone switch of panitu on panan bro… adhuku aprm charge eruthu bro. Y bro ipdi achu ipo ena panradhu bro. Again ipdi agama irukum nu ena nichiyam bro …80000 kuduthu vangi ipdi aga modhu romba kastam ah iruku bro .ena solution nu solunga bro …ipo ena pananum
hi bro, phone warranty la irukunga dont worry. defect iruntha service center la neenga claim panna mudiyum. original apple 20w adapter with original cable use pannureengala?
also eppothum junction box or spike buster with fuse mathiri use pannunga. building la earth line proper a irukanu check panikonga. to avoid any short circuit or power supply issues.
Belkin or any other brands use pannunga for expensive phones and laptops charging in such buildings.
https://amzn.to/3TsztNU
That will help bro.
Original adaptor and cable dha use panuren bro. Ivlo nal indha issue ila bro …andha same plug point la Android phone charge panna charge achu …ana iPhone charge agala. Again indha issue vandha apple service center la kamikuren bro . Service center la kudutha evlo nal agum , apps and pictures lam erase paniruvangala bro …
Dont worry bro, charging or some level of high wattage protection iPhone board level la irukunga. so charging delay or auto cut off mathiri options iruku. again two or three times aachuna check pannidarathu better. visit service center with cable adapter and iPhone. that will help.
Ok bro , thank you.
