My battery is draining very rapidly after 17.7.1 update
Kindly share last 24 hours battery page screenshot bro. with apps section visible showing top 3 or 4 apps.
Dear iPhone user after update your iPhone update your apps also then reset all setting 2 or 3 times then it will be ok
from 10PM till morning 6PM battery graph looks stable bro. youtube and no mobile coverage area or low signal area times we do see bit more battery drain. dont worry. 7 hours screen on time, and stable battery graph during idle time and usage is good.
do continue following the charging practice as suggested in our video bro. it will help to maintain over period of months usage.
