Battery health dropped 2 percentage i bought it on Nov 2023 15 pro. Last two months specifically I Have been using more for hot spot it reduced to 98 is that normal or any settings change required it is now running in 17.0.3. Please suggest solution
it is normal bro. when we use hotspot it does consume bit more battery power. so continue following the charging practice and it will be maintained well. for 3 months usage 2% reduce is totally normal. as you are already running 17.0.3 if there is no issues you may continue with same iOS version.
Else you may update to iOS 17.4 which is released recently. 15 Pro is a new phone so newer version of softwares wont affect the performance.
Thanks bro. Also if we don’t use the mobile it is reducing even I have turned off the background apps. Any solution for this
Kindly share last 24 hours battery page screenshot bro. scroll down a little and show apps section visible then take screenshot and attach here bro.
