iPhone 15 Pro Max Battery drain faster than usual
Recent ah iPhone 15 pro max romba seekirama charge koraiyudhu bro. Munnadi lam indha prob illa ippo oru 1 week ah romba fast ah koraiyudhu if I use insta or YouTube or WhatsApp anything. I have Apple Watch 9 and it’s connected to my phone all time.
hi bro, full apps section visible la irukara mathiri oru photo share pannunga. just top 5 apps visible la irukara mathiri. that will give good idea.
Romba noticable ah koraiyudhu sir. Up to date la iruku sir mobile and apple intelligence off panniyum paathuten.
Recent ah total factory reset um panniten sir. Watch la kooda romba koraiyudhu sir. Use pannamale 3 to 4% in just under 5 mins koraiyudhu watch la. Edhaadhu solution sollunga sir.
WhatsApp recent a battery consumption athigama irukunga for many users. but Instagram app another reason. namma video ku use pannumbothu battery power athigama edukumnga. above graph la 80% last charge pannirukeenga. overnight drain normal la thaan irunthiruku. morning to evening around 6PM usage la 30% nearer a vanthirukunga.
Suppose above 80% charge panniruntha upto 100% for example, around 6PM above usage ku 40 to 50% battery left agirukumnga.
Just tomorrow above 80% charge pannitu normal la neenga use pannura mathiri pannunga. eppadi iruku nu paarunga.
Innoru important factor, mobile data network signal strength 1 or 2 points irunthaalum network search ku athigama battery edukumnga. so athuvum oru reason a irukumnga bro. Pro Max model appadingrathaala ungaluku 1 day backup irukunga.
Tomorrow 100% la start pannitu around 20% varumbothu sollunga backup eppadi irukunu.
Ippo 18.2.1 update ku aprm konjo improvement theriyudhu sir. Nan neenga sonna maari pannitu solren sir. Battery graph ideal ah dhaana sir irukku? Anyway romba thnx sir.
ok nga. battery graph idle time la stable la thaan irukunga. but Whatsapp thaan usage athigama pannuthu recent a ella users kum irukara problem thaan. romba athigama illainga, but some percentage munna irunthatha vida athigama use pannuthu. already feedback sent, whatsapp update la fix pannuvaanga na expect pannurenga.
may be meta ai features naala battery consumption irukalaam. paakalaamnga.
Romba thnx sir. Battery life romba improve airuku sir.
good to know nga. battery 20% vara varaikum tomorrow paarunga. then charge pannumbothu battery drain eppadi iruku nu identify panna mudiyum.
also overnight usage illatho stable la irukunga. its good.
Mobile data use panna battery drain adhigam irukuma sir. And also about personal hotspot
Yes bro. mobile data use pannumbothu wifi vida athigama battery consume pannumnga. but outdoor la namma wifi la stay panna mudiyathu. so usage irukumbothu dont worry about battery. 20% around varumbothu charge pannitu use pannunga.
same for personal hotspot. device la warm temperature and battery drain irukumnga.
Good evening sir. Is this even normal? Mobile data la dhan run pannitu iruken.
Usage activity continuous a irukarathaala it is normal bro. in between charge pannaama morning 80 to 100% la irunthu start pannunga. once it reaches 20% around then check pannunga graph eppadi irukunu. that will help you to understand better bro.
your idle time graph looks stable and usage wise its reduce also seem normal.
You are using the device with 2 signal coverage strength bro. whenever we use the phone with low coverage then battery drain happens bit more than with full signal coverage. especially 5G does consume more power than LTE or WiFi. so whenever wifi available you can use it, otherwise the above graph will change when you are in good coverage area.
you have charged the device to 78% and started using it. from morning 6AM till evening 6PM it reached around 30% battery level.
So dont worry. you will notice improvements in upcoming days. do update to iOS 18.3 and continue using it.
Hello sir. Epdi irukinga
Apple Watch 9 la notification dot all time display aaguthu sir even though I don’t have any notification actually. Restart um panni paathuten. Enna panradhu sir?
Nalla irukenga neenga nalla irukeengala? WatchOS latest version updated a irukungala? check iPhone watch app software update section once bro.
Nalla iruken sir
Watch OS 11.3.1 la dhan sir irukku. But innum problem persist aaguthu enna sir panradhu ??
Checked with a friend and he is not experiencing same issue bro. temporary bug a irukalaamnga normal la restart la fix aganumnga. otherwise within apple watch settings reset all settings once try pannalaamnga. erase data kuduka vendamnga. just settings reset mattum pannitu use pannunga.
