Hello brother. Recent ah enoda 15 pro max la battery 100 to 99 drop aha 10mins ahudhu but 99 reach agum podhu 2 mins le 98% ku jump agudhu idle le. Apple support la try panen Elame normal ah iruku nu solitanga. But I know this is completely odd. Pls help me out bro.
hi bro, network signal strength fulla irukungala? or 2 or 1 point?
Signal strength 3 points brother. Recent 17.6.1 update ku piragu dhan brother indha issue. Oru percentage easy ah skip agudhu like 99 to 98 and 95 to 94 romba fast ah oru interval percentage skip agudhu. Device restart um paniten but no use.
if its software issue we can get it fixed with all settings reset or iOS Restore after taking backup bro. its a new iPhone, but the important thing is whether the battery drain happens continuously or particulr day or two.
If system services, background processing running at particular time, then we may see such battery drain. also when we use phone in low signal coverage area we see such drain too.
and with 5G we all are experiencing fast battery drain while using it, due to networks keep on switching between 5G to LTE or providing low coverage in many areas.
so observe for 1 week after performing all settings reset once. only if the issue still not fixed, then we can take backup and perform iOS Restore by connecting the phone with system. Tutorial available in our channel.
Let me know after 3 to 4 days usage bro.
After update dhan idhu madri iruku. Battery draining very fast. 1% romba fast ah skip agudhu. Ipo dhan all setting reset pani iruken. 4 days usage piragu I’ll post here. Thank you brother.
Sure bro. mostly it will be fixed with all settings reset. lets see.
