iPhone 16 Pro max Control Center Glitch in mobile data
Hi bro,
In my iPhone 16 pro max in the control centre sometimes a glitch or software issue I don’t know in control centre I can’t switch on or off mobile data and I’m currently in 18.6.2 update and to reset that I have to restart my iPhone
hello bro, that is not normal. I am using iPhone 16 pro max too, so far no such issue. 3 more days we will get iOS 26. if its software issue you will see it getting fixed. meanwhile try performing force restart once and check bro.
  1. Press and Release Volume UP Button once.
2. Press and Release Volume Down Button Once.
3. Press and Hold Power Button (Side button) till you see Apple Logo and release your finger.
hi bro 15 plus im currently using bbd sales la 16pro /max which best .. pls suggest mee
hi bro, explained it in todays episode bro. kindly check.
may help with deciding which iPhone to buy during this BBD sale.
Okay bro I will do and see
Bro and then I can’t speak in iPad through iPhone phone calls.when we call from iPhone and we can speak through iPad using the same account that option also not working for me bro.im using iPhone 16 pro max and iPad Air m3
Do check under settings - facetime - calls on other devices page, iPad is seelected on iPhone bro. that way calls will come in both devices when you receive them in iPhone or facetime calls in general.
