ok bro, system data yapdi delete panrathu or yapdi reduce panarathu na youtube vedios parthan atha koraika mudyuma enaku tharyala konjam guide panunga bro
system data automatic a manage pannurathunga. namma oru method la clear panna try pannalaam.
temporary help pannumnga.
macbook ipdithan mananuma bro
intha video only for iPhone bro. mac la evlo system storage consume agirukunga?
20gb varaikum somtimes 23 gb varaikum increase aguthu bro
Namma data store pannumbothu athuve reduce agidumnga. free storage affect aagama athuve auto adjust aagum dont worry bro. above 50GB+ and increase agite iruntha thaan issue irukumnga. suppose namma data athigama store pannumbothu system storage around 10 to 15GB varaikum maintain aagum. apps, data poruthu system resource usage aagumnga.
ok bro, shopla use panrathuku browsing online usage ,iphone back up and ios restore , photo ,vedios editing,ms office,lightroom, photo shop,shopla use pana plus studying purporse macbook air m4 13 inch 10cpu 10gbu 16/512gb poduma 6-7 years use pana macbook air poduma bro, windows laptop madri lastest update vara vara performance reduce aguma yan friend laptop vangurathuku wait panraapla ungalda already soli irukan he is asking this question he is already using dell inspirion 5 th gen core i5 performance slowa iruku so ada madri performance reduce aguma mac book air m4 chip
laptop night shutdown pani than vaikanuma illa next day use panra madri irunda laptop on vaikalama, laptop shut down panama use panra nala battery life reduce aguma ?
Macbook air handle pannumnga. moderate video editing, photo editing ellame possible. sila projects heavy ya iruntha mattum hiccups irukum, but romba notice panna mudiyathunga. normal video editing tasks ellame pannalaamnga.
Windows apps requirement iruntha kandippa windows porathu thaan better choice nga. adobe and other softwares pirated use pannuvaanga windows la thaan convenient irukum appadina mac choose panna koodathunga.
Mac la pirated apps availability romba kammi. find pannurathu tough bro. so adobe products ku windows laptop always best choice.
Macbook porutha varaikum shutdown kattayam illainga. thevai pattuchuna shutdown pannalaam or iPhone mathiri work continue panna appadiye next day use pannalaamnga just lid close panni vachutu.
bro tommorrow macbook m4 pro 24/512gb iplanet showroomla eduka porom bro nala choicea 7-8 years usage , 512 gb enough ? poduma , neenga ena storage use panrunga in mac
1-bro yesterday an friend laptop buy panyachu m4 pro chip in iplanet . bro, laptop on pannumbothu apple logo white color sligta dim ayudu bright agura madri iruku idu normala bro , yan laptopla m4 air la apdi illa iplanet katan idu ambient sensor solranga enaku tharyala bro idu normala.
2-bro m2 air os podrathuku try panran
os format panum podu
disk utility
veiw- show all device poitu apple ssd select panidu
click panidu
erase kudukum podu
NAME- untiled
format- APFS
SCHEME- GUID partition map
erase pana automatic restart agudu then shut down panidu , again boot panum podu install using intstaller then, machintos hdd select panidu agree kuduthu install panna vandyathuthana bro
ipdi thana format pananum and installation
good bro. normal thaanga. applecare+ thevai na potukonga just 3 years protection kaaga.
its a good spec. nalla work load thaangum. so dont worry.
macOS clean installation video check pannikonga.
just few small steps difference varalaam, but mostly same.
thank u bro
bro m4 pro os reinstall pana apple logo dimma and bright agurathu fix aguma apdi illa mac os 26.1 update wait panalama new macbook pro 26.0.1 battery drain agudu enna panalam 26.1 update wait panalama bro
bro software nama install pana warrenty problem varuma care plus iruku bro potachu neenga sonanala podachu bro
bro neenga macos latest yapdi format panidu install panrathu pathi youtube vedio pannuana yalarkum use fulla irukum bro
bootable device unga vedio parthu ready panitan 15.7.1
format method confuse agudu while installing mac os disk utlity poidu enda format select panrathu tharyala bro unga youtube vedio and other youtube vedios parthan then apple website parthan little confusion edu choose panrathu
apple ssd select panuna inda formatla pananuma
NAME- Macintosh HD
format- APFS
apple website la parthan
macintos hd select panitudu
name- macintos hd
format- APFS
potrukanga edu choose panrathu confuse iruku
apple ssd select panna
apple ssd select panuna inda formatla pananima
NAME- Macintosh HD
format- APFS
format step matum konjam help panunga bro ,os install pana trichy pona 340km up and down travel pananum iplanet os restore pana solranga ,step matum neenga solita ada follow panipan.NANUM os install pana learn panipan RECOMENDED STEP solunga bro please
waiting for your reply bro
Hello bro, New mac ethukaaga macOS Reinstall pannureenga? also new mac so warranty la irukurathaala neenga apple service center la pannalaame? ethavathu issue appadina.
latest OS just update pannuna pothumnga format pannitu install panna thevai illaainga. ethavathu issue appadina thaan out of warranty la irukumbothu nammale format pannitu install pannalaam.
Macintosh HD select pannuvom and mac la ore partition thaan irukum.
Video la solliruntha mathiri format pannitu macOS install pannalaam problem irukumbothu clean installation kaaga. ovvoru update varumbothum just update pannuna pothumnga within macOS Settings page - Software update section.
ok bro yan friend no need reistall solran ,
bro warrentyla irunda mac os nama install pana koodatha bro warrety issue varuma ,
bro 26.0.1 update pana piragu battery nikala solran , finder automatic full screen exit agudu nanum parthan , iplanet katathuki os 15.7.1 reinstall pananum songa , trichy pora madri irunda 350km varudu up and down so only he ask me help bro adan bro na ungalta katan os installation neenga sona corrrecta irukum bro
bro 26.1 update vanda fix ayuduma wait panna sollava bro
bro 16 promax 26.1 update vanda piragu panava 18.7.1 use panran
apple screen sharing 16 pro max la conect panna apple supportla avanga persional details like notes photos eduvum screen sharingla download or veiw panida matangala sina dought bro
appadi illainga. warranty irunthaalum namma pannalaam. open and service thaan panna koodathunga.
But within warranty period la any issue apple service center la free ya panniikalaamnga.
Yes iOS 26 issues irukunga. 26.1 update today or tomorrow varum. update panna sollunga. next3 to 4 days apram improvement irukumnga.
Urgent illati 26.2 varaikum wait pannalaamnga. suppose 26 features ippo experience pannanumna mattum panna sollunga. still bugs iruku but previous updates vida bettera irukunga.
appadi panna maatanga bro. apple support is trusted only. neenga thevai na notes, other apps face id lock pannikalaam during screensharing.
also new question ku separate post create pannunga with different title. inga already different topics discuss pannitom search and find future la easy ya irukumnga if its separate topic. Good night bro.
ok bro thank u next seprate topic podran
