iPhone 18 pro getting hotter while video recording
Hi Bro,
We bought iPhone 18 pro last month and we tried video recording continuously for 10 minutes in indoor Birthday party. It got very hot and can’t handle we kept aside.They video annd photo got freezed Its because of case we are using?
hello bro, its possible due to iOS specific bugs we may see such heating issue while using camera app. have you updated to iOS 27.2 recently? Normally when we record 4K 60fps we may notice such heating issue, but within 10 minutes is too short.
you can adjust the video resolution level slightly. 4k 30fps will be good to record too. or 1080p 30fps based on your requirement.
case normally dont heat up the phone or mostly the design allows to distribute heat outside too. you can try recording a video without case and see if any change happens too.
my observation is mostly its software specific and heating is normal and manageable upto certain level. do update to latest 27.2 and restart iPhone once then record a video and let me know bro.
