iPhone Battery Drain problem, How to Fix?
Hi bro i purchased my iphone 12 (128) gb by july 2022, I followed your battery charging practice, just few time i couldn’t follow because i was out. the battery health was 100% till November 2022, later after the update it reduced to 98%, then i updated 16.2 again the battery percentage reduced now its 96%. I yet to update the 16.3, this kind of battery percentage drain is normal or any problem with battery, im a new user this is my first iphone. Please reply
hello bro, for 6 months 4% is normal bro. dont worry. you can continue following the same charging practice and it will be maintained well. we will get 2.5 years average time to reach 80% as I mentioned in our videos.
by the way, how is iOS 16.3 overall performance for you?
Hye sir i’ve not yet updated the ios 16.3. I will do it by tonight, after getting the reply from you thought of doing. Shall i go for the update
Oh ok bro. Do use it for three four days and share your feedback.
