iPhone Heating issue while charging
Bro I am using iPhone 13 and I have heating issues while charging or using the phone also battery draining issue this time update can I install via iTunes
during fast charging heating is normal bro. when we dont use the device while charging heating will reduce too. do perform “settings - general - reset - reset all settings” once. then you will see improvement with the draining issue. make sure to update to latest iOS version.
