Bro ippo aprox aah iphone 14 plus 128 gb evlo ku vachu sale pannalam 8 month old
50 to 55K around range ku sell aagum bro. as 256GB model available for 60K price range.
Hi bro ennaku (primary) your SIM sent a text message nu screen la kaamichuchu adhu een bro vandhuchu edhum issues ah bro ? Konjam sollunga bro een adhu vandhuchunu
network side la irunthu intha feature off pannanumnga. call your mobile sim provider support. for example if its airtel, then contact airtel support and ask them to deactivate this service. then it will stop bro.
Like one time dhan idhu vandhuchu adhuku aprm varala bro i want to contact jio or else i can leave it bro
Again repeat aachuna jio support ku once pesidunga bro. Else no need to.
Hi bro
1.Na storage kaaga iphone la ulla video aah google drive la upload pannunen then na google drive la andha video play senju paatha quality kammiya iruku but na iphone file app google drive la play panni paatha good quality la iruku whats the reason bro
2.then phone la video size vera kaamiku after upload to google drive adhula vera video size kaamiku
3.then adikadi files app la google drive touch panni ulla pona “content unavailable” nu adikadi kaamiku bug aah iruku
4.then google drive cloud storage dhana bro then een bro upload pannadhuku aprm app storage increase aagudhu iphone storage adhunaala increase aagudhu
Hello bro, Google drive compressed video play pannirukumnga. but if we download the file then original file download aagumnga. to save bandwidth google have such measures in place. it uses youtube like video player which automatically adjust the quality.
same file again iPhone or computer la download pannitu once check pannunga. you will see the actual file size. in Google photos app compress aagumnga. when we use free account. but in google drive it just stores the original file as it is without any compression.
possibly network error reason a irukalaamnga. as we try to stream from google drive frequently. try it in wifi connection once and see too.
particular file neenga view pannumbothu google drive app kulla antha file download aagumnga. only then you will be able to view that file. so downloaded file size iPhone storage la kamikumnga. it wont be like live streaming using temporary data. suppose neenga antha file stream pannalaina it wont be downloaded again to your google drive app.
Thanks for your information bro
One more confirmation drive la store panna file size drive la compress aagi irukum once we download on iphone or pc it will return to its original size ? Dhana bro
Yes bro exactly.
