Hi Anna,
Hope you are good and all fine.
Anna. My iPhone storage is 128GB and it’s full now. Photos app memory is showing as 77GB. But the photos inside all collective will not even be crossing 25GB. However, trying to copy my PC only 10GB getting free space.
Any suggestion Anna? It could be some other issue from my side when I am copying.
All good bro. thank you. hoping you too. Did you check Recently Deleted Folder? any recently deleted photos, videos still present and occupying the storage? do check.
Also iPhone model and current iOS version?
Hi Anna, The Recent Deleted Folder is empty Anna.
Model 14 pro and version 17.2.1
Kindly share iPhone storage page screenshot here bro. just to have a look.
All those Photos and Videos moved to local computer bro?
Almost i have copied everything na. Some photos can be left anna and remaining can delete
Ok bro, this could be software bug related issue. storage details after deleting the content update agurathuku time aaguthunga. just perform a simple restart once and check. Make sure to update to latest 17.3 version as it does contain plenty of bug fixes.
If the storage is freed up. then perform “Settings - General - Reset - Reset All Settings” once and check again bro.
that should fix it. let me know if that helps.
Sure anna. Will do that and update you on the same.
Thanks anna
