iPhone upgrade suggestions - camera & model suggestion
Hey bro, need your opinion. My brother has been using iPhone 7 Plus since 2016, but now it’s finally gone. He’s planning to upgrade, and we’re confused between iPhone 15 Plus, 16 Plus, 15 Pro, or maybe even waiting for the 17. From your experience, which one do you think is the best choice right now for long-term use? Especially for camera performance is 16 Pro really standing out, or is there another model you’d suggest as better? Also, comparing 15 Pro vs the 17 do you think 15 Pro is excellent for both selfie and rear cameras, or is 17 noticeably better?
hi bro, 17 will be good choice if budget allows. else go with 16 plus if you can see good price difference between 17 and 16 plus during deals and offers. Pro cameras always stand out no doubt about that. 17 has got improved camera system this time with selfie camera especially. so if budget wise ok means go with 17 model bro.
if you prefer pro camera system with faster usb c transfer speed (if needed) then you may go with 16 pro model.
