iPhone voice breaking issue during phone call
Hi bro i am using iphone 11 pro max . i checked every part its working fine i checked on 3utools and The problems is happen everytime in indoor only (wifi calling enabled) the opposite person cant hear my voice for few seconds its breaking i also cant his voice . Can u tell any solution for this problem . I am using vi sim card.
hello bro, do you have full signal coverage and still experiencing that issue? iOS updated to latest version and your sim network?
Yes bro latest version,when full coverage it is working fine bro. But when signal bar reaches 1/2 the issue is happening , i have another phone iphone 14 plus (father) using 2sim like vi e-sim and airtel physical sim.But there is no problem bro it is working fine.(my sim network is vi bro i don’t know how to update sim)
hi bro, if its eSIM no need to update from our side. but if its physical sim getting new sim card will help fixing any firmware related issue. if you are experiencing issue with vi physical sim card on your iPhone, then try this suggestion.
That helps to fix it normally bro.
Thanks bro . I check it out
