Is it Worth Buying iPhone 11 64GB for 20K?
I am planning to buy iPhone 11 64GB from my friend, The battery percentage is around 85%. They are planning to give for 20,000. Is it good price or is there room to negotiate for 15k, considering the battery replacement after 80%.
In 5 to 6 months you may have to change your battery bro. so getting it around 16K will be good buy if they are open for negotiation.
Try to negotiate
