Hi, I am using iPhone 15 as main driver, I feel like the battery is dropping heavily in recent times, it completed only 259 cycles and dropped to 92% is this normal
hi bro, for 7 months usage 8% reduce is bit extra. like 1% additional reduce than normally it should be. but the cycle count reduce kind of looks ok. depends on our usage and charging pattern ofcourse.
following the charging practice as suggested in our channel? like around 20% without draining the battery to zero percentage frequently?
