Hi Bro,
Naan iPhone 15 use pandren, Jio and Airtel sim vechu irukken, Airtel la Internet speed ah irukkunga bro, Airtel 4G la average 100mbps varuthunga bro.
Jio la 4G & 5G both layum maximum speed 15-25mbps thaan varuthunga bro, jio new sim um change panni paathuten, friends oda phone la Jio 4G Max 80mbps sometimes varuthu nga, ithu ethunala nu yaarachum sollunga bro, Jio thaan ennoada primary Sim so, ithu ennna pandrathunu sollunga bro…
Both Sim yum eSIM layum try panniten nga, Physical Sim layum try panniten nga, still the same…
Hello bro, speed test results device poruthu change aagite irukumnga. neenga youtube video, netflix mathiri stream pannumbothu difference irukaanu paarunga. quality issue or buffering issue mathiri. speed test score connect agura server and need connect agirukara network band poruthum change aagumnga.
Amanga bro, ellame check pannen nga, youtube video buffer aaguthunga bro, reels um buffer aayitte irukunga, but Airtel internet la try pannen, buffer eh illama work aaguthunga bro
software level issue va iruntha once all settings reset and network settings reset la fix aagumnga. wifi la intha issue illa but only jio 5g la mattum use irukungala?
