M1 MacBook Air usb pendrive not visible
I bought MacBook M1 Air last week. in addition to that i bought usb adopter also to connect my pendrive. but i couldn’t read my pendrive even though i have changed settings in finder and disk utility management. please guide me how to solve this issues!
Hi bro, which adapter you bought? do share the link here, also did you check with other pen drives? to identify whether the problem is with the adapter or with the MacBook air port, it will help diagnosis when we check with other pen drives.
Another important thing is, make sure to format the pen drive in a windows PC as exfat file system. that will make read and write working in macOS too. If its NTFS, we should be able to read only.
But let me know after trying the first suggestion whether other pen drives work with the same adapter in your MacBook or not.
I am using Oxlaw usb-c male to usb 3.0 in my MacBook Air M1 for my usb pen drives, it’s working fine.
