Possible to Turn OFF Low Power Mode When we connect Charger to iPhone?
Low power mode charge pota udana automatic ah off aha eethum
You can create an automation bro.
Shortcuts App - Automation tab open pannunga. When section la “Battery State” - “Charger Connected” or “Is Charging” choose pannunga.
Do section la, “Turn OFF Low Power Mode” set pannunga.
You can search the functions from the button search bar and add actions bro. do give it a try and see if it works.
