Hi bro , how to disable the option of power off when the phone is locked? Phone lock la irukum pothu volume up down and power button press panuna switch off option vanthuruthu… after theft intha option vachu phone switch off panitangana then namba epdi bro iPhone ah track pana mudiyum ?
hello bro, since iPhone 12 phone off aanalum tracking possibility irukunga. find my feature will still work with tracking. Explained in our recent episode.
So it is important to make sure these settings are ON. It is not possible to enable password when we try to turn off the iPhone. But if a thief turns it ON and as long as battery backup is there, your iPhone will still be trackable bro.
That increases the chances of finding the device if its just kept OFF.
Thank you so much bro its very informative
