Hi Bro. I want to upgrade my iPhone XR. Which is the best option to consider iPhone 16 or IPhone 16 Pro. I don’t have any budget constraint and I don’t play much game’s and want lighter weight phone.
hello bro, iPhone 16 is sufficient for most users and coming from XR you will notice good difference with 16 model. but only if budget isnt a problem and you need that camera upgrade, 120Hz display and premium build of titanium frames you may consider iPhone 16 pro model.
Both are lighter models compared to the plus and max models though. iPhone 16 is lesser weight than iPhone 16 pro, but here my suggestion is to experience both devices personally at apple showroom once and then decide bro.
Thanks for the guidance bro
