bro what will happen if i leave battery as it is even its going low and low percentage
it will drain fully and turn off bro. which is not recommended if you are planning to use the device continuously. as the batteries are precalibrated in the factories. you can charge and use the device.
rarely if you dont have access to charger it may drain. but doing it frequently is not recommended.
