hi bro 15 pro max new device today vangitan bro , bro camera use panumpodu heat agudu bro edu normala bro 17.3 version
with 15 pro and pro max models camera records in high resolution bro. especially with 4K and HDR shoot you will see such temperature increase. dont worry, you can use it bro. heating will be managed automatically. proper case wear pannita heating directa feel pannatha mathiri irukumnga. if you feel like wearing case, otherwise not necessary.
heating during normal usage is a problem. when gaming or camera usage is normal bro. due to heavy processing.
Camera picture edukum podu heat anuchu bro normal apps usagela illa bro then nama speakerla songs katalum heat anuchu bro adan ungaluku message pana pro
understood bro. its new iPhone, unga usage ku thaguntha mathiri optimise aagumnga. just keep updating latest versions and you will see improvement.
