hi bro yan friend 17 pro max vangi irukapla data transfer from Mac and charging ,Belkin cable ok va any issues Varuma ,
Hi bro, in another post you have shared about Adam elements cable.
Belkin is Good choice to consider. you can use it for mac and iPhone. problem ethuvum illainga. adam elements cable reviews um paarunga. rendula ethunaalum ok thaan.
Belkin 10gbps cable price athigamnga. adam elements cable data transfer speed kammi, so price um kammi.
intha cable 100W charging support potrukaanga. pathutu decide pannunga.
bro yan friend dubai mall macbook m4 air vangunathuku accessories offerla 40% discount apple thunderbolt 5 3 cable vangi irupala 1 katan bro 2500 rs katan iphone 17 pro max macla use panikalama iphone ku issue problem varadula , 2500 rs vangava india warrenty claim aguma 11months bill iruku
wortha vanagalama how to find origal cable
issue ethuvum varathunga. vaangalaam. no problem.
ok bro another post yan friend macbook related katan bro then macbook online and offline diagnosis results both are same and result will be same ?
reply pannitenga. kindly check.
