20W charging MacBook Air
Is it possible to charge MacBook Air with  20W adapter in case of emergency. Just asking.
Yes bro. you can charge it with any USB C adapter. Just using a branded adapter will make sure the cable and macbook will be safe from short circuits or other power related problems.
