Suggest some 20w Adapter for iPhone 12 under ₹800!?
other than apple 20w adapter, you may use any branded adpater bro. Anker should be good to consider.
Also suggest best magsafe magnetic charging device @iRobinPro
You may check with Belkin brand bro.
there are other brands available on amazon, but do check user reviews before placing order.
