2TB r 1TB SSD for 16 pro max
Hi Bro iam using 16 pro max 256Gb. Already i exhausted 256gb of phone memory and also bought 200gb cloud which going to exhausted. Instead of going to cloud advice shall i go for SSD. Can you confirm me the best brand for SSD also whether 1TB is safer or 2TB is safer for backup. As many videos more TB it will corrupt quickly. Please advice
Hello bro, 1TB is sufficient for most users. but going with 2TB is totally depending on our usage. if you want to use it for long term and planning to store more videos, then you may go with 2TB SSD. else 1TB storage.
I am using Samsung T5 SSD and it works good till date. its been more than 4 years I think.
Check their latest T7 Shield series.
Bro can I directly connect the 16pro max with this ssd and transfer the photos and videos
Yes bro. with iPhone 15 and 16 models we can directly connect usb c drives like this ssd.
