Robin bro, how are you bro? In your AirPods 4ANC vs AirPods Pro 2nd gen comparison video, you asked to put apple care + within 60 days of purchase so that after two years we can replace the AirPods. Explain about that bro.
I am good bro. hoping you too. within 2nd year warranty ending time we can replace airpods bro. so to avoid battery exhausted or lifetime gets over within that 2.5 years to 3 years time. you get new airpods which will work well for another 2 to 3 years time.
Hi Robin bro,
Will apple simply give a replacement for a certain fee within the 2nd year or there has to be certain criteria matched? Please clarify.
yes bro. they wont ask any questions as we are paying the claim fee to get replacement. just we have to follow the instructions from service center technician. that will be good.
Got it bro. I usually don’t drop my earphones and so should I get the battery replacement within the window or get a replacement?
yes bro. airpods overall battery lifetime is 2.5 to 3 years maximum. so getting new airpods allow us to use it for another 2+ years. so totally 4 to 5 years usage for the amount we spend.
