About Buying iPhone 15 Pro in USA
Hi Bro,
I am planning to buy an iPhone 15 pro . One of my friend told me that there won’t be any physical sim tray if bought in US. Will that be a problem if I intend to use the phone in India ? And will I be able to use dual eSIM option in India ?
Hello bro, Its not going to be a problem buying USA iPhone 15 models and using it in india. you can use Airtel and Jio eSIM in India. a friend of mine using it without issues. if thats alright go for it.
