About Buying Second Hand MacBook Pro
Robin Bro I Got Deal That 16Ram 512SSD MacBook Pro 2021 in 2nd hand, I checked the serial number and Confirms that the product is in warranty expires in December 2023 But my doubt is the product price 1,20,000 Only and previous owner just used 4 months the battery cycle count is 5 and the battery condition is normal. What about your thoughts should I buy, what are the things I should check physically and also I cross check the seller and he only sells Apple products only and it seems it is a genuine seller what should I do now? Your thoughts
hi bro, this must be M1 model, and the price looks suspicious. Do buy from a trusted shop or seller. Avoid COD or any other online delivery options. Its under applecare+ so its safe. if there is any issue then you may get it repaired or replaced at apple service center by paying service fee.
We have used macbook buying tips published already in our channel. you may check once too.
Yes Bro 2021 MacBook M1 Pro 16ram 512ssd I Checked Serial number and the product have Apple Warrenty, expires this December 2023 But The Price is look suspicious
Serial number checks wont be effective bro. is the from local shop or seller?
Actually it is from a used Apple products dealer their profile in social media looks genuine
ok bro. do visit their shop and inspect the product in person. that will be helpful. mostly sellers will keep things transparent to do more business. just avoid ordering it online or COD or courier options.
