About iPhone 14pro max battery
@iRobinPro hai Anna After latest OS 16. 6.1 update the battery performance okay ? or battery drain? This is my one day graph na. Can you check and tell me
overnight battery drain seems to be higher than usual bro. Do try these battery saving tips and do some location and privacy settings optimisations too bro. see for next two days how the performance overall works out.
Ok Anna, and I buy this phone last month, this why I have doubts
ok bro. above steps try pannitu use pannunga. if there is any problem let me know. we can try some fixes.
Ok na thank you.
Anna I think now my battery drain problem ok, and still I not update 17 Anna. So Better update 17.1 ??
Yes bro. give some time and update bit later after 17.1 comes out. battery graph looks good and stable.
Thank you na
Anna my battery health level 97% ku vathuruche, yesterday paakum pothu 98% ipo 97% ewalo quick ka battery drain aaguma na? iOS 16.7.1 run naguthu
Last month 7th la vaaguna phone na,can you please explain what I won’t do?
iPhone model and purchased last month bro? Also charging practice here after follow pannunga, this will help to maintain it overall.
Yes Anna last month peaches pannathu, iPhone 14 pro max na, I think 2 week la 3% drop ahegina. and charging method follow panran na
2 weeks la 3% drop aaga chance iruka na?
no bro. 2 weeks 3% romba athigamnga. overall purchase pannuna date la irunthu thaan namma calculate pannanumnga. 2 months overall usage appdina sudden drop aanalum 2% mela aaga koodathu. unga usage eppadi irukum? screen time athigam irukuma? and 20% around varumbothu charge pannurengala or frequent battery drain to 0% agumngala?
Anna sariya 20% varum pothu charge pannuwan na, naan wait panna maatan until 0% varum varaikum. Per day one time only change poduwan na, also 1 hlfa day ku peragum charge pannuwan pubg game 3 games maari play panuwan awalothn na.
ok victor. dont worry. same practice follow pannunga. within 1 year manufacturer warranty irukunga, so issues iruntha apple service center la check pannikalaam. overall 2.5 years average varumnga to reach that 80% mark. will see how it goes when we average it for 11 months around usage.
Hai anna good afftanoon, just now i update 18.1, there are not showing (clean up option in gallery) also (reduce interruptions) option not showing, I already restart my phone But not showing Anna what reason??
(14 pro max)
good evening bro. clean up option is available from iPhone 15 pro and above models only bro. Reduce interruption is not showing to some users due to some bugs bro. expecting fix very soon.
Thank you for your information Anna :pray:
