Hi guys after my ios 17.5 update device heating while charging on both 65w adapter and also on apple 20w charger same issue is still on ios 17.5.1
during fast charging heating is normal bro. from 20% till 80%. if its overheating then it automatically cut off or slow down charging speed. were you using the device by any chance while charging?
yeah i’ve used it once while charging but rest of the time i don’t use the device while charging and also maximum i’ve use 80% limit charging.so from 20 to 80 generates more heat after the update
it must be normal bro. due to fast charging. dont worry. heating is managed automatically both software and hardware level. it wont affect the device. only if you see temperature warning then we can try some troubleshooting steps. now its not necessary. you can disconnect and start using the device when needed.
