I am currently using iPhone 15 pro and MacBook Air M4. I am able find airdrop connection of iPhone in MacBook, but the MacBook is not visible in iPhone..I don’t know what is happening.
For last few..I am facing this issue..I have many troubleshooting..still nothing resolved..
hi bro, is the bluetooth also ON in macbook? in macbook system preferences search for airdrop. is the toggle allow handoff turned ON? and airdrop permission set to contacts only?
once restart macbook and then check whether macbook is showing on iPhone or not.
I have factory reset my MacBook couple weeks ago, and it have been working good..from yesterday onwards, I am facing similar issue all over again.
Yes per your instruction, I have checked, toggle is turned on and airdrop sets to everyone.
Still MacBook not showing on my iPhone
try this method once bro. When i had similar issues it worked for me. just whenever mac is not showing on iPhone airdrop, just turn off wifi of macbook and then turn it on again. then check in iPhone that it shows macbook in airdrop page to transfer or not.
