Airpod pro 2 clone worth buying?
Can i buy a Airpod pro 2 Clone For my IPhone 15 i need to experience the Ecosystem Feature
hi bro, not all the features will work, but we try clone products at our own risk. make sure seller also provides warranty. if its stopped working in few days then we can approach same shop to get replacement.
Some of our audience are using it bro. so far decent review. you can check and go for it.
